pazzfam Posted December 3, 2017 Share Posted December 3, 2017 Hi I want to know if the attached stable / barn need to have the roof manually drawn in chief. The building has a ope court yard so I labeled the courtyard open below in the structure tab I set no roof, floor, or ceiling but the automatic roof keeps putting a roof over courtyard. I know how to build it manually but curious if there was an easier way Thank You Adam LOUNGE -OFFICES FTRS 24-36.pdf LOUNGE_-OFFICES_FTRS.plan Link to comment Share on other sites More sharing options...
RL-inc Posted December 3, 2017 Share Posted December 3, 2017 Try labeling the courtyard "court" which should have roofs and ceiling turned off by default. Open below only affects floor below not ceiling or roofs above. Link to comment Share on other sites More sharing options...
pazzfam Posted December 3, 2017 Author Share Posted December 3, 2017 Thanks for the response but that did not work either Link to comment Share on other sites More sharing options...
RL-inc Posted December 3, 2017 Share Posted December 3, 2017 I am guessing that you have the daily and roof unchecked in that room structure dialog. It may be seeing it as an island room and that may be causing the issue. Try making the open area on the left end void of any defining walls. Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 3, 2017 Share Posted December 3, 2017 This is what I came up with, DJP Link to comment Share on other sites More sharing options...
pazzfam Posted December 3, 2017 Author Share Posted December 3, 2017 Wow I can not believe you did that fo me I really appreciate you time and I can review this and learn a lot from your video THANK YOU!!! Adam Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 3, 2017 Share Posted December 3, 2017 here is a quick answer, I think it's a bug right now my sound isn't working but look closely just remove the roof and ceiling from that little room and it will apply the roof correctly then just patch that area with a roof. I think it' a bug o report it haven't seen that one before. Link to comment Share on other sites More sharing options...
