EmmaCox
Room Divider won't Delete
I made a chief plan of an existing cottage layout with different ceiling heights on the main floor. Now I have saved the existing cottage layout to alter the plan but since we will be taking the whole second floor off and starting fresh with new floor joists we are going to make the main floor ceiling one height. So I went ahead and changed this on chief... Now that I've cleared the whole main floor plan so that there are only a few partitions (because it will be open concept) when I try to put a new railing to go to the basement a room divider keeps showing up and it won't let me delete it. I've tried playing around with the railing that goes to the basement. If I delete the railing the room divider disappears, then I re-draw the railing to go to the basement and the room divider shows up again and won't let me delete it.
I've attached the file and put some notes in red to try and show what the issues are. Sorry my explanation on here is confusing lol.. Any help would be awesome!!
Winter Nov. 27 2017 - Room Divider Issue.plan
Chief wants to connect island rooms, like the one where the stair is, to other walls.
You can put these walls on their own layer and turn it off.
The default behavior Eric mentions can also be turned Off it needed ...not sure if it will lead to other issues in the Plan though ?  and then you can delete it.
Uncheck the Connect Island rooms box in the Pic.
You may want to add your own Room Dividers Back to designate the Kitchen , Dining Area , Living Rm etc as CA tends to "remember Rooms" sometimes even if they are no longer there and it should stop any automatic walls returning....
I would recommend that you keep the option to automatically connect island rooms turned on.
An "island" room is created when you have an interior room that is not connected to any exterior walls.  If they are not connected, you could have problems with things like room definitions, floors, ceilings, moldings, and possibly other things.
If you don't like where the program puts the automatic room connectors, then you can manually draw your own.  Once you have drawn your own, you can then delete the automatic one and it should not come back.
If you don't want to see these room connectors, then just put them on their own layer and turn off the layer.
    27825
    ChiefDallas
    ChiefDallas
  • Similar Content
    • By JMarkey
      In the attached sample plan, I wanted to divide a Kitchen/Living Room area into two parts, to allow different flooring materials to be placed. However, when I snap a "room divider" wall between Points A (lower right corner of the wall) and Point B (the lower left corner of the cabinet) the interior wall shrinks to the left. It also looks like the room divider is snapping to the center of the wall edge rather than the corner.
      I made a before (left plan) and after (middle plan) of the same area to illustrate the problem that occurs. I put in a couple of CAD lines to show how the wall is shrinking. If you grab the end of the room divider wall and try to move it back to the lower corner of the wall, the wall just shrinks more. Note that the room divider wall also extends from Point B to Point C for room division to occur, because cabinets never participate in Room Definition.
      The right side plan has a 1/32" line collinear to wall that is then extended down to Point B and on to Point C.
      WORKAROUND PROVIDED BY SUPPORT
      Start by drawing a short collinear line segment from the corner of the wall and then extend the room divider down to the corner of the cabinet. I found this collinear line can be around 1/32 inch which makes it cosmetically a non-issue. Making it smaller will probably work, but it gets hard to snap to the collinear line.
      Support has submitted this issue to the developers.
      Maybe someone knows another way to do this.
      Hope this helps.
      John
      Room Divider Question - X8.plan
    • By SapPata
      Dear friends.
      My Room divider below just draw as a 1 Line. I want it show as a 2 Lines. How to change this ?
      Best regards
