rispgiu Posted December 1, 2017 Author Share Posted December 1, 2017 45 minutes ago, Kbird1 said: something like this quick example perhaps.... M. that looks nice, thank you Link to comment Share on other sites More sharing options...
Kbird1 Posted December 1, 2017 Share Posted December 1, 2017 I made a Room Polyline ( room under Turret), converted it to a Slab and then set each step's height and stretched each successive staircase layer out after using copy and paste in place to add the 3 steps..... If you need the plan let me know.... 1 Link to comment Share on other sites More sharing options...
rispgiu Posted December 1, 2017 Author Share Posted December 1, 2017 1 minute ago, Kbird1 said: I made a Room Polyline ( room under Turret), converted it to a Slab and then set each step's height and stretched each successive staircase layer out after using copy and paste in place to add the 3 steps..... If you need the plan let me know.... Thank you for the explanation. I am working on it. I'll let you know if I need the plan. Link to comment Share on other sites More sharing options...
rispgiu Posted December 2, 2017 Author Share Posted December 2, 2017 Hello all and thank you for your help on this project. The developer I am working with just informed me today that he wants the roof to be a 6/12 and the ceiling no higher than 8ft. Also no brick, since he is planning for this plan to be more of a starter home. So I am thinking about re-drawing something much simpler. I will put this plan on hold and finish it when I have some free time, I will update this post with final pictures and possibly video when done Link to comment Share on other sites More sharing options...
GeneDavis Posted December 2, 2017 Share Posted December 2, 2017 Well, that's a seismic shift, innit? Link to comment Share on other sites More sharing options...
rispgiu Posted December 2, 2017 Author Share Posted December 2, 2017 Just now, GeneDavis said: Well, that's a seismic shift, innit? it sure is Link to comment Share on other sites More sharing options...
Kbird1 Posted December 2, 2017 Share Posted December 2, 2017 Quite the change ....hope he is seeing you right for the time spent so far..... Well you have a Plan to use as a template , change Level 1 to 8ft stud and put a simple 6/12 gable roof on it and see what he thinks before going too far .....sort of like " you thinking something like this ? " so you don't waste too much more time.... M. Link to comment Share on other sites More sharing options...
rispgiu Posted December 2, 2017 Author Share Posted December 2, 2017 4 hours ago, Kbird1 said: Quite the change ....hope he is seeing you right for the time spent so far..... Well you have a Plan to use as a template , change Level 1 to 8ft stud and put a simple 6/12 gable roof on it and see what he thinks before going too far .....sort of like " you thinking something like this ? " so you don't waste too much more time.... M. yes definitely a big change. What I did he pretty much what you suggested. Now that this design is approved so to speak, I am moving on to the next problem. He is asking for the ceiling to be vaulted. given that it is a gable roof I created the one sided gable with a ceiling plane. However on the door side the roof is cutting into the entrance. Any suggestions? Link to comment Share on other sites More sharing options...
Kbird1 Posted December 2, 2017 Share Posted December 2, 2017 CA will do Vaulted Ceilings Automatically if you uncheck the "Has Ceiling" box in the Room's DBX ....looks like you did these manually? Did you leave the Dutch Gable over the front Door area? only other reason I can think that it is shaped that way unless done manually? M. Link to comment Share on other sites More sharing options...
rispgiu Posted December 2, 2017 Author Share Posted December 2, 2017 This is what the front looks like. Link to comment Share on other sites More sharing options...
rispgiu Posted December 2, 2017 Author Share Posted December 2, 2017 here is the plan, if you are curious on what I did. I am open to suggestions Bella storia.plan.zip Link to comment Share on other sites More sharing options...
Kbird1 Posted December 2, 2017 Share Posted December 2, 2017 1st thought looking at image above would be to swap the roofs , give the garage a hip and house a gable , so garage isn't so prominent in Street view or make both gables...cheaper to build too usually and a double gable looks nice ...to me at least... M. Link to comment Share on other sites More sharing options...
rispgiu Posted December 2, 2017 Author Share Posted December 2, 2017 3 minutes ago, Kbird1 said: 1st thought looking at image above would be to swap the roofs , give the garage a hip and house a gable , so garage isn't so prominent in Street view or make both gables...cheaper to build too usually and a double gable looks nice ...to me at least... M. That's a good thought. would you extend the gable to be over the front door as well ? Link to comment Share on other sites More sharing options...
rispgiu Posted December 3, 2017 Author Share Posted December 3, 2017 4 hours ago, Kbird1 said: 1st thought looking at image above would be to swap the roofs , give the garage a hip and house a gable , so garage isn't so prominent in Street view or make both gables...cheaper to build too usually and a double gable looks nice ...to me at least... M. What do you think about something like this? Any thoughts on the roof? Link to comment Share on other sites More sharing options...
Kbird1 Posted December 3, 2017 Share Posted December 3, 2017 13 hours ago, rispgiu said: What do you think about something like this? Any thoughts on the roof? For that design , I think I would lower the pitch of the Garage roof to match the Front Entry's (3-4deg.? to shingle minimum slope) so you see less Shingle. Columns are nice but in a budget Build add Costs that could make that front Room bigger instead of a Porch ...porch could be added as a Custom Addon/Upsell , by extending main roof forward and start other RH Gable higher so it picks up the front Door too perhaps. Can also do something really simple , and once again add Upsells like a Nice Corner Column on porch , Shingles and a Bellyband to make the front look more "Custom" Depends on the Builder's budget and Costs locally , I am guessing 6/12 Roof is cos local Lumberyard has them in Stock , so they are Cheapest. And on 1st time Buyers expectations in your Area..... the 1st Pic is probably tooooo Cheap so 2nd pic and perhaps a nice column instead of railing in pic. M. Bella_Storia_Simple.plan Link to comment Share on other sites More sharing options...
rispgiu Posted December 3, 2017 Author Share Posted December 3, 2017 2 minutes ago, Kbird1 said: For that design , I think I would lower the pitch of the Garage roof to match the Front Entry's (3-4deg.? to shingle minium) so you see less Shingle. Columns are nice but in a budget Build add Costs that could make that front Room bigger instead of a Porch ...porch could be added as a Custom Addon/Upsell , by extending main roof forward and start other RH Gable higher so it picks up the front Door too perhaps. Can also do something really simple , and once again add Upsells like a Nice Corner Column on porch , Shingles and a Bellyband to make the front look more "Custom" Depends on the Builder's budget and Costs locally , I am guessing 6/12 Roof is cos local Lumberyard has them in Stock , so they are Cheapest. And on 1st time Buyers expectations in your Area..... the 1st Pic is probably tooooo Cheap so 2nd pic and perhaps a nice column instead of railing in pic. M. Bella_Storia_Simple.plan Thank you sir, these are really nice. Link to comment Share on other sites More sharing options...
rispgiu Posted December 3, 2017 Author Share Posted December 3, 2017 3 minutes ago, Kbird1 said: For that design , I think I would lower the pitch of the Garage roof to match the Front Entry's (3-4deg.? to shingle minium) so you see less Shingle. Columns are nice but in a budget Build add Costs that could make that front Room bigger instead of a Porch ...porch could be added as a Custom Addon/Upsell , by extending main roof forward and start other RH Gable higher so it picks up the front Door too perhaps. Can also do something really simple , and once again add Upsells like a Nice Corner Column on porch , Shingles and a Bellyband to make the front look more "Custom" Depends on the Builder's budget and Costs locally , I am guessing 6/12 Roof is cos local Lumberyard has them in Stock , so they are Cheapest. And on 1st time Buyers expectations in your Area..... the 1st Pic is probably tooooo Cheap so 2nd pic and perhaps a nice column instead of railing in pic. M. Bella_Storia_Simple.plan Btw, you were correct, 6/12 is what they are asking for Link to comment Share on other sites More sharing options...
rispgiu Posted December 3, 2017 Author Share Posted December 3, 2017 Mick, what is the name of the texture you used for the siding on the attic wall? Link to comment Share on other sites More sharing options...
Kbird1 Posted December 3, 2017 Share Posted December 3, 2017 It is just one of the Hardi Shingle Panels from the South Folder , I usually use the Single shingles but for a budget build the Panels are less costly labour wise. (you can check in he Plan i posted too) The Bellyband / Watertable is just a P-Solid , since Iwas only doing a few pieces across the front but if you want it all the way around the House use this method : (quicker and all auto positioned) https://www.chiefarchitect.com/support/article/KB-00070/adding-a-belly-band-to-a-structure.html 1 Link to comment Share on other sites More sharing options...
rispgiu Posted December 4, 2017 Author Share Posted December 4, 2017 On 12/3/2017 at 11:44 AM, Kbird1 said: It is just one of the Hardi Shingle Panels from the South Folder , I usually use the Single shingles but for a budget build the Panels are less costly labour wise. (you can check in he Plan i posted too) The Bellyband / Watertable is just a P-Solid , since Iwas only doing a few pieces across the front but if you want it all the way around the House use this method : (quicker and all auto positioned) https://www.chiefarchitect.com/support/article/KB-00070/adding-a-belly-band-to-a-structure.html Thank you Link to comment Share on other sites More sharing options...
rispgiu Posted December 4, 2017 Author Share Posted December 4, 2017 On 12/3/2017 at 0:53 PM, solver said: Mick knows this, so this is directed at the OP. You can also draw connected CAD lines in plan and convert to a Molding Polyline. Draw them out from the walls, then drag and snap to the wall. Set height and add molding. Add breaks for doors etc. Thank you Eric Link to comment Share on other sites More sharing options...
