wall dimensions not showing
crosscutter55
PLEASE HELP  !!! When i drag a wall the dimension use to show as i was dragging it  :(  I see it shows on the very bottom of the screen but not along the wall as i drag it :wub: When i draw 4 walls i will not even get an interior dimension to change the dimension of any wall
Are you using the same Template Plan or did you Start with a Blank OOB CA Profile Plan ?  sounds like you lost a bunch of your defaults , they could be re-imported if needed , though did you check Temporary Dims are still turned on?   View>Temp.Dims >  is it Checked?
you may have clicked the icon for it by accident ?
check these settings in the pics :
