joey_martin Posted December 4, 2017 Share Posted December 4, 2017 This issue has been around as long as I have used Chief. Not sure why it hasn't been addressed. Link to comment Share on other sites More sharing options...
Archnot-Boltz Posted March 14, 2018 Share Posted March 14, 2018 It's a heck of a Long Time Issue for a program that will occasionally, automatically build walls that I don't want. I've been scratching my head about this one for a long time. BB Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 14, 2018 Share Posted March 14, 2018 This particular issue was addressed in X10. We now get automatic foundation walls when we check Create Wall/Footing Below for porches (or similar exterior rooms) that are defined by railings and invisible walls. Link to comment Share on other sites More sharing options...
Draftsman-don Posted May 23, 2018 Share Posted May 23, 2018 I found this thread after struggling with the same issue. There are lots of good suggestions and information here. I can concur with Alaskan_Son that this works in X10 but it didn't work for me in X9. Unless I'm still doing something wrong in X9 it is still a bug. X10 works beautifully though. Link to comment Share on other sites More sharing options...
dennmill Posted September 18, 2018 Share Posted September 18, 2018 On 11/8/2017 at 12:06 PM, johnny said: The reason I believe this hasn't be an issue yet is its so rare to build full foundations under porches. I would add that in the Willamette Valley of western Oregon (Eugene, Roseburg, Salem, and upwards to Portland) although the frost line is only a few inches, they still very often put in a footer and stem wall when building a porch. Seems like this method is common enough in different parts of the country that CA (and Home Designer (Pro which I'm using) should be fixed/improved to incorporate some foundation options for porches instead of almost tying our hands. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted January 3, 2025 Share Posted January 3, 2025 On 11/7/2017 at 11:57 AM, javatom said: You can make it look right in 3d by telling the slab to be as thick as the depth you want the footings. A lot of builders would only do a point load pad where the columns are located and make the porch an elevated slab. In this instance, the software is doing it right. You would have to manually place a pad for the columns on the foundation layer. Please support the request below to update the porch floor... 1 Link to comment Share on other sites More sharing options...
