Sign in to follow this
DMIAF1
HELP - 1 story ranch house w/ a raised entry landing
Hi all,
I've been trying to figure this out for a couple days now. I'm sure it's an easy solution that I just can't find the answer to.
I have a one story ranch-style home that has an elevated landing at the front entry. Does anyone know how to raise the walls to the top of the landing just for this small area at the front?
I've attached a photo below so you can see what I'm working with. I appreciate any help!
I'm not clear on what you want to do.
In Chief, you don't really "raise walls". Do you want to raise the ceiling over the steps and landing?
You may get better help if you attach the file.
Just curious are you a Premier user or Home Designer?
Yes, I suppose I could raise the ceiling over the landing. But if you notice the whole front door isn't even visible when the stairs and landing are in place.
I have attached the dwg file. Does this help? I am brand new to the software. We are using Chief Architect Interiors X9.
Boyett.dwg
3 minutes ago, solver said:
To get any help, you will need to describe what you want.
Chief creates .plan files, which is what you should attach -- make sure the plan is not open in Chief. But we need to know what you are trying to model.
It helps if we know what title (Premier or Interiors) and version (X8, X9 etc) you are using. You can add this info to your signature by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left. Doing so makes it always available, and this info is often key to providing a good suggestion
We are using Chief Architecture Interiors x9. I have attached the DWG file for your viewing.
My goal is to raise that small area where the front door entry is located. Once you enter the front door of the house there is a landing that is higher than the rest of the house, you will go down the three stairs and the remainder of the house is on the same "lower" lever. Does this make sense?
Boyett.dwg
So, don't attach a .dwg file.
Raise how? It's already raised.
Think about floor and ceiling heights. In Chief, walls just (mostly) fill in between them.
So, where do the floor and ceilings need to be?
Okay, I wasn't able to attach the .plan file because it was too large which is why I exported it to a .dwg file. Not sure where to go from here.
Raise the wall at the front and the front door so that it is even with the landing. There is a pony wall that is dividing the dining room from the entry. But as it stands now if you were to open the front door to go inside, you would walk right into the landing at your knee caps.
So are you suggesting I raise the ceiling height and adjust where the door starts on this part of the wall and fill it in that way?
9 minutes ago, DavidJames said:
I'm assuming you want to have a raised entry like this?
Yes!! That is exactly what I need to do! Are you able to assist me with this?
Create a room for that entryway that you want raised via invisible walls or the room divider tool.
Once created, you can open up the Room Specification DBX and, under the structure tab, raise the floor and ceiling height to whatever you want.
Thank you so much!!! This was most helpful. I am still playing with the details a bit so I may have some follow up question for you in the next day or two. I really appreciate your help, thanks David!
Hi David,
Your advise to create the raised entry was very helpful. Just a few follow up questions as I am just getting back around to working on this project. I feel like I've done trial and error for every setting but just keep getting the same results or worse!
1. Do you know how to edit the exposed wall that is showing the studs? I need a half wall to divide the space from the dining room.
2. I am also not sure how to get the foundation slab to become invisible.
If you are able to help, thank you!
Also, Happy Thanksgiving! boyet.thumb.JPG.93d3e4513059126d15fa17854bc762af.JPG
It says the file is too large! Do you know a way around this?
I've attached a photo but am unsure if I am able to attach the entire file...
I am heading out of town, if I cant get back with you in a timely manner today I will reach back out on Monday.
Thanks again!
Try zipping the file , it has to be under 25mb to post here .....
delete interior item like furniture or cabinets if needed in a copy of your main plan 1st if needed.
You can always try zipping the file, or uploading it to a cloud drive (Dropbox, Google Drive etc) and pasting the download link.
Thanks for the help, I've made a zip file of the project plan. Are you able to view this? The foundation is still visible and I can't seem to attach the top of the stairs to the landing. The wall studs are still exposed too.
Hope y'all had a happy thanksgiving!
Boyett_Project_(2).zip
I ended up changing your railing to a half-height wall and using polyline solids to cover up the areas that were displaying concrete.
I also made a room molding polyline in the raised area so that I could control where the molding was going/displaying (unfortunately I didn't have your baseboard profile in my library so you'll have to change it back).
Boyett_ProjectR1.zip
That looks AWESOME!
Now.......to figure out how you did that!!!
I really appreciate your time and help David.
Did you have official training on this software or are you self taught? I am trying to expand my knowledge and the chief arch videos are the best for me in terms of learning the program.
I'm self-taught. Much like yourself, I found that the videos that Chief Architect has online, as well as the knowledgeable people in this forum is more than enough help.
You're clearly utilizing both options so you're on the right path. Keep it up :)
    27494
    theCADStudio
    theCADStudio
  • Similar Content
    • By Designer100
      Hey guys,
      I ariginally had cable rails and now I cannot get stairs to go back to noarmal stairs. Ballusters are not showing and I need to deleter the cable rails that are showing up in specs. Stairs has been move from another part of floor plans. Proably something simple.
      Can someone help?
      Thanks for any help.
      Richie_house._La_OPT._2_02_17.2020.zip
    • By DeckQuestions
      I'm trying to get stairs that look like this:
      They look like this right now:
      How can I achieve this?
      Thanks.
    • By Designer100
      I have designed a pergola and a deck. I cannot get the terrian to show right. It needs to be zero of level at back of deck by pool deck and slowly slope down to a bayou. it needs to be 36" to grade at edge of outer deck Then a stair going down to the end of stair which is around 5 fr lower that top of deck. I have not did much terrian and would appreciate your help. This is just a remodeling and adding a deck from the pool.
      Thank  you,
      Nerwell
      newell.cheatheam@gmail.com
      Pergola_.plan
      11X17.layout
    • By ChiefArchitect
      The living room offers a peek to the upstairs living area via the stairway. The glass panel railings and open concept design create a mechanism for the big windows on the first floor and the high shed windows on the 2nd floor to collaborate on the sharing of light and air between floors.
    • By MN_JohnH
      I am stuck on this one. I have a railing at the top of the stairs that I can't seem to get rid of. When I delete it the stair opening disappears. When i re-add the stair opening the railing across the top comes back.
      Stair rail problem.plan
