SNestor Posted August 15, 2017 Share Posted August 15, 2017 Is there a way to send multiple floor plans to a layout page...with different layers turned on for each time the plan is sent to layout? What I have is a design of an outdoor room...option #1 adds a fire pit. Option #2 adds a trellis over the fire pit. I want to send (3) copies of the floor plan to the same layout...that shows the (3) options. But...it's seems when I turn on the different layers...all the plans show the same thing. Am I missing something? Thanks! Link to comment Share on other sites More sharing options...
SNestor Posted August 15, 2017 Author Share Posted August 15, 2017 2 minutes ago, SNestor said: Is there a way to send multiple floor plans to a layout page...with different layers turned on for each time the plan is sent to layout? What I have is a design of an outdoor room...option #1 adds a fire pit. Option #2 adds a trellis over the fire pit. I want to send (3) copies of the floor plan to the same layout...that shows the (3) options. But...it's seems when I turn on the different layers...all the plans show the same thing. Am I missing something? Thanks! I figured it out... The answer is to create new layer sets that turn on the individual layers as needed. Therefore: - Layer Set #1: Base Plan layers - Layer Set #2: Base Plan layers + Fire Pit layer - Layer Set #3: Base Plan layers + Fire Pit layer + Trellis layer Link to comment Share on other sites More sharing options...
dshall Posted August 15, 2017 Share Posted August 15, 2017 You need a different layer set for each view. Apparently you are using the same layer set for all 3 views. 2 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 15, 2017 Share Posted August 15, 2017 You could also use different Reference Layer Sets to display the additional items. 2 Link to comment Share on other sites More sharing options...
SNestor Posted August 15, 2017 Author Share Posted August 15, 2017 11 minutes ago, dshall said: You need a different layer set for each view. Apparently you are using the same layer set for all 3 views. Just now, Joe_Carrick said: You could also use different Reference Layer Sets to display the additional items. Yep...I got it. I created new layer sets for each view. Problem solved. Thanks for helping me out! Link to comment Share on other sites More sharing options...
