EricWMLim Posted July 22, 2017 Share Posted July 22, 2017 Hi all, I have encountered a problem in X9 Premier for a selected manufacturer - Atlantis Outdoor Kitchens -> Door Styles -> Perma - Tek Door Styles -> Key Largo - Key Largo Door I selected this particular door style (consists of vertical panels) for my cabinet drawers/doors and because I have various widths for my base cabinets, the distance between each vertical panel varies depending on the width of the base cabinet. See the word document for my explanation. How can I make the distance between each vertical panel consistent? Thanks Eric Kitchen base cabinet door.docx Link to comment Share on other sites More sharing options...
MarkMc Posted July 22, 2017 Share Posted July 22, 2017 Doors are set to resize consistently across the total width, there is no way to force the distance between the verticals to remain constant as the door resizes for that door. The only option would be to make assorted custom door symbols. Link to comment Share on other sites More sharing options...
EricWMLim Posted July 23, 2017 Author Share Posted July 23, 2017 Hi Mark, Thanks for taking the time to look at my query. No problem but I thought I will try seeking advice from the forum group if there is an alternative method. Cheers, Eric Link to comment Share on other sites More sharing options...
GeneDavis Posted July 23, 2017 Share Posted July 23, 2017 I did not look at your file but presume you have a cabinet door panel that is made to look planked. See the image attached. Mark has identified a solution, and I am curious to hear whether you think it is worth the effort to go about doing this. I'm also curious to know about other software (2020, Revit, . . . ) that addresses this more cleanly. Link to comment Share on other sites More sharing options...
MarkMc Posted July 23, 2017 Share Posted July 23, 2017 1 hour ago, GeneDavis said: I did not look at your file but presume you have a cabinet door panel that is made to look planked. See the image attached. Mark has identified a solution, and I am curious to hear whether you think it is worth the effort to go about doing this. I'm also curious to know about other software (2020, Revit, . . . ) that addresses this more cleanly. The door he is working with has no rails or stiles. I doubt that 2020 would behave differently, that is on my old computer at the office (I refuse to load it onto this one) To be able to keep the space between the lines consistent a stretch plane would be needed between each. I don't don't know the detail at the joint- correct width? chamfer or radius? Attached is a plan with one way to have cabinets that resize and keep the same detail size. (I also don't know if as the cabinet gets smaller there are fewer panels?) The door made from a psolid has only1/16 chamfers. Trick is to set stretch zones and use individual panels BUT for it to work the cabinet construction gets messy. Alternative is as I noted to make individual door symbols per size-have an example in the plan ready to be turned into a symbol (BUT I usually make them from wall cabinets so do that first) Is it worth it? I fuss a lot to make sure all my rails, stiles and raises remain consistent, BUT ....lets assume 1/8" chamfer, total distance between edge of chamfer is 1/4", standard on a 15" door. That means that on a 24" wide door it goes to 0.04" (I don't use doors larger than 21" so would be less). Now print that out at 1/2" to the foot. Difference in print is 0.0025". Even with 1/4" chamfer printed variation is 0.005" Key Largo.plan Link to comment Share on other sites More sharing options...
GeneDavis Posted July 23, 2017 Share Posted July 23, 2017 I have built kitchens with planked doors like that. Tongue and groove v-joint boards and battened rear sides. I have also bought fronts from doormakers that mill the grooves into solid-stave glue-ups. I prefer the jointed boards look. Depending on door width, the panel either gets a board at centerline or a joint at centerline. This means the stretch is at the edge planks. Looks as if one could do any job nicely making just six or eight doors, half of them center-plank, half groove at center. Cabinet width would determine which door to use. Link to comment Share on other sites More sharing options...
EricWMLim Posted July 25, 2017 Author Share Posted July 25, 2017 Hi Mark and Gene, The other solution I can think of is to import the fixture door into Sketchup as a collada object and then modify it in Sketchup. After that then import back into Chief architect. I will give it a go and keep you guys posted. Thanks, Eric Link to comment Share on other sites More sharing options...
