aixrrr Posted July 14, 2017 Share Posted July 14, 2017 i finish a plan, "save as" to desktop, then save a copy to external hard drive. both same names, same file. when i go back to the desktop, and unplug the external drive, the desktop file won't show all the files and keeps asking me to plug in ext. drive so it can grab the files. i must be saving wrong....but i save a whole file under that certain name, then drag to ext. drive and they don't match. hard to explain and i don't feel i have done a good job of it. Link to comment Share on other sites More sharing options...
BillMc Posted July 14, 2017 Share Posted July 14, 2017 Sounds as though you are moving the file, rather than copying it. Are you holding down "control" while you select and drag the file to ensure that it is copying? 1 Link to comment Share on other sites More sharing options...
KirkClemons Posted July 14, 2017 Share Posted July 14, 2017 10 hours ago, aixrrr said: then save a copy to external hard drive. To backup what Bill is asking, what exactly is the process used to save a copy to the external drive? I would think using 'Save as' from chief, twice would accomplish what you are trying to do, but so would a simple file copy. Can't be sure without the exact wording of the error you are seeing though. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted July 14, 2017 Share Posted July 14, 2017 If drag and drop is being used then that is a move command. If working in CA, then as Kirk describes you would do a Save As and specify the other directory. If working in a Windows file explorer window then you need to use the copy/paste function. 1 Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted July 14, 2017 Share Posted July 14, 2017 Just did a quick check on the Windows file explorer drag and drop command. If you hold down the "right" mouse button and drag the file it will ask you if you wish to copy or move the file. Link to comment Share on other sites More sharing options...
aixrrr Posted July 14, 2017 Author Share Posted July 14, 2017 spent about 1 1/2 hour with apple tech support today....and she told me if i was using icloud to say docs, like plans and layouts, and also saving to external drive, i might run into problems because i am confusing my ext. drive. that sounds nutty to me but maybe true. it is rather confusing as you might expect. so i guess i should just keep saving to icloud and hope it never gets comprised or attacked by a starship hacker system? Link to comment Share on other sites More sharing options...
aixrrr Posted July 14, 2017 Author Share Posted July 14, 2017 yes bill i was. holding down control and dragging it. i am on a mac and i am thinking most of you are PC....so maybe that is causing me problems unique to mac. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 14, 2017 Share Posted July 14, 2017 12 hours ago, BillMc said: Sounds as though you are moving the file, rather than copying it. Are you holding down "control" while you select and drag the file to ensure that it is copying? If they moved the File off the Desktop it would no longer be on the Desktop to Click on to re-open it , but I am curious to know after saving to the desktop , what you are "dragging" it to? A shortcut to your External drive ? into an Explorer Window , open to the External Drive? ok I see you are on a Mac now ...so things maybe a bit different... Link to comment Share on other sites More sharing options...
