How to maintain roof framing after deleting roof plane?
zowie123
Hey all,
Anyone found a way to do this?  I tried copying and renaming, but when the roof plan is deleted, the framing gets deleted?
I thought it would be a faster way to make an arbor, but not..
Curious if it can be done?
Thank you,
Barry
I often do this.
There are a couple of ways I do it.
1. Ensure you un-tick all the auto roof framing check boxes so they become manual framing members.
OR
2. Make a glass roof plane that will be invisible in 3d views.
Rick
Ahhh...
Yes!  I think Eric may have the best approach.  I was doing it in the wrong order:  The correct method is: Create roof plane, frame roof plane, copy framing, delete, roof plane, then paste framing back.
I was pasting then deleting roof plane..even when renamed to a different layer the framing deletes when you delete the original roof plan after pasting.
Copy Framing--Delete roof plane--paste framing...simple..Thank you all.
