capitaldesigns
Windows showing up in schedule that are not on plans
I am using X-9. I am working on a small addition project. When I make the window schedule I am getting a window 1 that does not exist. It shows it as 32"x24 1/2". I do not have any such window
in the plans. I have selected not to show existing window in the schedule. Even with that none of the existing windows are this size. In the addition I have 4 windows, all the same size. The schedule is calling these window 2. Window 1 callout does not show up on the floor plans so I have no idea where window 1 is coming from.
I have attached the plan. Can someone take a look and see where this window is coming from. I need to get rid of this callout in the window schedule.
Thanks,
Mike
Naimi Planning Drpt Submittal (2).zip
Mike, They are duplicates of the Double Arch tops in the back side of the "Existing Living Room" that you mulled.  Interesting that the callout does not show up until you tab to select the window though, that does seem a little strange.  Have a great weekend B)
Good sleuthing Chop : )  I had just opened the plan, had added the Room Name column to the schedule and was just beginning to search the living room when you posted.  The reason the labels don't show up is because "Show Component Labels" would have to be checked in order for that to happen.
EDIT:  I see Eric mentioned the Room Name thing too while I was typing up my response.  I guess I showed up a little late this time.  Good job guys.
So then they are not duplicates, they are components and need to have "Include in schedule" deselected. Two in front of Living Room and two in back.  Thanks Michael.
Thank you for the help. How get rid of the callout in the window schedule ? I tried in the floor plan and the double arch top window do not show on the floor plans.
I then went to the elevation views. They do show up in the elevation view when I explode the mulled units. I then can see the window schedule label and able to
uncheck "include in schedule". Another problem is that when I re-mull the windows again the windows do not mull together correctly. The exterior trim around each
window does not merge together and show as one trim around all 3 windows as they originally did. How do I get the trims around each window to merge together
and show as one trim around all 3 windows ?
Also, why does the window schedule callout of the mulled units not show up on the floor plans ?  In this case I do not want them to show up in the window schedule
since they are existing. On a project where these are new windows I will want the window schedule callouts to show up on the floor plans.
Thanks,
Mike
Mike,  you don't have to explode anything.  Just select your mulled unit in the area where the individual component window is and then hit tab to actually select the component window.  Once selected, open it's DBX and uncheck "Include In Schedule".  Do that for all offending windows. That should be all there is to it.
    28146
    JonasN
    JonasN
