MarkMc
Tray dividers and RO for cabinets with open door
 I put in a lot of tray dividers and thought it would be nice to use those with the new open door feature. In the past I've had to force those onto a cabinet, presents problems resizing or moving. Thought of this when I woke up.
Plan attached with sample cabinet to and a couple of door symbols. Open the cabinet dbx to see how it all works. Open door symbols to see how to set up your own for other accessories. I plan on using this for a trash, Hafle Lemans and a few other things. Also included a single a Rev-A-Shelf Chrome tray divider. You'll have to make your own (or alter Joe C's :) if you want wooden ones.
Tray dividers in place.plan
Does something like these pull out pantry drawers exist anywhere in our libraries?
Not AFAIK. You can download the entire Rev-A-Shelf catalog in 3d DWG from their site but still a pain to convert.
I'd make it in Chief -attached is a start and some parts- cabinet with "drawer" symbol is set with method Alaskan Son Developed. You'd still need to add rails to it. I mostly use Hafele so didn't bother to mess with it. Besides, be good practice for ya :)
RAS panbtry PO.plan
Thanks Mark.
Now that I have mastered the fine art of ray tracing I guess it's time for me to expand my knowledge base and move into designing custom cabinetry. :D
5 hours ago, MarkMc said:
I'd make it in Chief -attached is a start and some parts- cabinet with "drawer" symbol is set with method Alaskan Son Developed...
Thanks for the credit Mark.  I appreciate it.  It always feels nice...especially knowing when one of my cockamamie schemes is being utilized by someone besides me.  I'm sure you know the feeling.  Thanks again :)
Sure thing Michael, works better than the one I was using, was a good tip.
    28308
    BPIETZ
    BPIETZ
  • Similar Content
    • By goshgolly
      I'm sure this has been discussed, but I can't find anything specific that answers this question.
      I'm trying to create a simple vanity with two drawers and an open shelf underneath (see inspiration image of "vanity").  I simply can't figure out a way/remember how to add a shelf other than by using the shelf command. While this works visually, it treats it as a separate part of the vanity, thereby creating two separate pieces.  In the Working Plan and Kitchen and Bath View plans, the shelf shows up on top of the sink while the 3d view shows the shelf in the correct place!  I guess maybe it's, in part, a layers thing?
      I know there has to be a better way of doing this.  What am I missing/forgetting?
    • By VisualJoy
      Good afternoon,
      I am trying to design a kitchen but am having issues with both lower and upper cabinets that are convex.  I understand using the different door styles for the front, but how do I make the back of the cabinets fit?
    • By nancyscial
      I am trying to show a recessed wall cabinet bottom for inserting a light strip.
      I need to be able to show the bottom of the cabinet recessed up by 1 1/2" with the sides still down. The doors should cover the recess also.
    • By Garreth
      Hi all any suggestions on how to adjust cabinet to angled wall.
      see image..
      note this cabinet will only be half functional from front on but the back will be chamfered to suit the wall.
      I have tried to look thru the options but nothing seems to address my requirements.
      thanks in advance
    • By LynnConstruction
      I've used an older cabinet program (Cabinet Vision) for producing cabinet cut sheets for some time now. I would like to use one program start to finish to simplify things. Our company owns our own cabinet shop and is used to mass cabinet production using these cut sheets. Is there a way to export cabinet data only through Chief Architect that I can give my cabinet builders to assemble off of?
