Marina_R Posted May 25, 2017 Share Posted May 25, 2017 Hi, Can someone help me ray trace this kitchen plan? My ray tracing turns out really bad and I dont know what else to do :/. I need a really good professional 2-3 images of different angles. Can someone help me put in the right lighting sources and for the materials to turn out more realistic? 4512_Fair_Oaks.plan Link to comment Share on other sites More sharing options...
Electromen Posted May 25, 2017 Share Posted May 25, 2017 I don't have these several of these materials: One is; unnamed_model4c238c8656140cd9f3f0c71893b70a40.png Link to comment Share on other sites More sharing options...
Marina_R Posted May 25, 2017 Author Share Posted May 25, 2017 @Electromen , I forgot I used outside sources. Hm, Can you attach a camera view so I can see what is missing? thanks Link to comment Share on other sites More sharing options...
Rich_Winsor Posted May 25, 2017 Share Posted May 25, 2017 I had a quick play with your plan. Kind of working with a minimalist canvas as materials are missing as Greg noted. The first thing you should do (and I know it sounds strange) is have Chief build a roof for you. It doesn't have to be the actual roof, but even though your rooms have ceilings, you will have problems with light bleeding at the tops of the walls if there is not also a roof over the room. I toned down the Intensity levels of all of your Spot Lights, but I kept the "white hot" highly emissive Reflective Material Class for the hanging globes as they seemed to Ray Trace ok. Don't know if the Armstrong flooring had a Bump Map but it didn't come along with the plan. To give the floor some life I changed the Material Class to Polished so the floor will show some reflections. Other than that I basically went with whatever you had in the plan. 1 Link to comment Share on other sites More sharing options...
Marina_R Posted May 25, 2017 Author Share Posted May 25, 2017 @Rich_Winsor OH MY!!! This looks incredible!! My ray trace looks 100 times worse. This looks so good compared to mines! Is it possible if you could post screenshots of all your settings that you used to create this ray trace? I also need a master bath that I need to ray trace and need some guidance to achieve what you have. I would really appreciate it and be very grateful!! Thank you!! Link to comment Share on other sites More sharing options...
Marina_R Posted May 25, 2017 Author Share Posted May 25, 2017 @Rich_Winsor Also your camera view looks spot on. My camera views always stretch the side walls and make the windows, doors and whatever on the walls to be really stretched. Can you please tell me the settings you used for the camera view? Thank you!! Link to comment Share on other sites More sharing options...
Kbird1 Posted May 25, 2017 Share Posted May 25, 2017 Use the File>Backup Entire Plan Option and then post a zipfile if possible ---- that will include all the missing textures for someone to help you . If the Plan is over 25mb zipped then you would need to make a copy of the plan and delete items from areas not needing to be raytraced and then backup the Entire plan and post that zipfile. Link to comment Share on other sites More sharing options...
Rich_Winsor Posted May 26, 2017 Share Posted May 26, 2017 Here you go Marina. I originally edited your plan in X9, but I see from the paths to the missing textures that you were using X8 instead. So here is your plan in X8. There are two saved camera views. You can open either camera and start a Ray Trace. In the Ray Trace Current View box click on the Edit button and you will go to the Ray Trace Options dbx where you can see all the settings that were used for the shot. You can also open the Camera dbx's and see all the camera settings there. Hope this helps and here is the second camera image. 4512_Fair_Oaks-X8.plan Link to comment Share on other sites More sharing options...
Marina_R Posted May 26, 2017 Author Share Posted May 26, 2017 @Rich_Winsor Dude your awesome!! Thank you. Ye I am in x8.. I'll play around with it and go by your settings!! Thank you. I used your two images at work and everybody loved the way it turned out !!! :)) You were credited for sure. Link to comment Share on other sites More sharing options...
