tommy1 Posted May 15, 2017 Share Posted May 15, 2017 In X8, if you make a room, place a base cabinet, then go to the library, select and place a GFCI outlet over the cabinet, Chief will by default, place the outlet at 42" which is above the cabinet. In X9, if you do the same thing, Chief will NOT place the GFCI outlet from the library above the base cabinet. It would be nice if this could be fixed in the next update so we don't have to take extra steps or at least make it work like it did in X8. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted May 15, 2017 Share Posted May 15, 2017 Tommy, This isn't a bug. X9 gave us the ability to place outlets ON cabinets, so there isn't a separate library category for "cabinet mounted outlets" anymore. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted May 15, 2017 Share Posted May 15, 2017 One step forward -- two steps backwards. Such is life. Link to comment Share on other sites More sharing options...
MarkMc Posted May 15, 2017 Share Posted May 15, 2017 An option is designate room as kitchen and use autoplace- still likely have to move some but the GFCI's will be on the wall at correct height. Link to comment Share on other sites More sharing options...
