Roof Issues
Designer100
Newell,
Delete your Roof Baseline Polylines (on the Roofs, Baselines Polylines layer) - you have 2 of them. You shouldn't need to use Roof Baseline Polylines on that plan - although there is nothing stopping you from using them if you want.
Change the ceiling heights of the his and hers rooms to 97 1/2" to match the rest of the house - if that is what you want
Define the front porch with an invisible wall and make the ceiling height 97 1/2".
Turn on Auto Rebuild roofs - make sure Make Roof Baseline Polylines is turned off.
The roof should auto build correctly.
That house should have no problem with the auto roof builder - you just need to get all the ducks lined up in a row.
You will need to clean up the walls, floors, etc, in the front porch.
If you really want to use Roof Baseline Polylines, build them now and they will build correctly - but in this case, I wouldn't worry.
You could then delete the invisible wall defining the front porch.
I just had another look at this and reread your original post.
I forgot about the metal roof out the back.
Check the deck to have a roof over.
I also think that you will have to drop the roof pitch to more like .5:12, otherwise the roof geometry doesn't work
