OttawaP Posted April 15, 2017 Share Posted April 15, 2017 I know this has been covered before but for the life of me I can't find any threads. Although, I did just spend the last couple hours getting lost in all sorts of other interesting threads in my search. Fwiw, the room has no ceilings above unchecked, the problem disappears if I pull back the glass wall a little from the exterior wall and lose the room definition. This is where I've sort been trying to make it work. Tried a few different approaches such as drawing the walls after the roof vs before etc. I just end up with the same thing more or less. Can anyone guide me to the appropriate thread or solution? Thanks. Link to comment Share on other sites More sharing options...
justmejerry Posted April 15, 2017 Share Posted April 15, 2017 What wall type did you use to create glass wall? I use just a pony wall with interior 4 with tile layers and glass shower 1/2" on top. I have no issues like that when I pull wall tops down to where I want them. Link to comment Share on other sites More sharing options...
OttawaP Posted April 15, 2017 Author Share Posted April 15, 2017 I just used glass shower walls also. I pulled them down from the 97 1/8 to a reasonable height. Is your shower still a separate room? Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 15, 2017 Share Posted April 15, 2017 You also need to turn off "ceiling over this room" on the shower's "Structure Tab" DJP Link to comment Share on other sites More sharing options...
OttawaP Posted April 15, 2017 Author Share Posted April 15, 2017 David, it is also turned off, same as the main room. Link to comment Share on other sites More sharing options...
dshall Posted April 15, 2017 Share Posted April 15, 2017 9 minutes ago, solver said: Uncheck Use Room Ceiling Finish I think that is the answer. Link to comment Share on other sites More sharing options...
OttawaP Posted April 15, 2017 Author Share Posted April 15, 2017 That did it ! Would never have thought of that, thanks so much. These finer chief points are what really stump me. Link to comment Share on other sites More sharing options...
