Lewdis Posted April 11, 2017 Share Posted April 11, 2017 I have created a layout with the scale 1:100. When I try to print this on A3 paper I dont get it exact. 13000mm is on the paper 12,7cm and not 13cm. Hope someone can help me out here. Link to comment Share on other sites More sharing options...
Lewdis Posted April 12, 2017 Author Share Posted April 12, 2017 I got it working after changing the printer settings. Thanks anyway Link to comment Share on other sites More sharing options...
glennw Posted April 12, 2017 Share Posted April 12, 2017 Your layout should normally be at a scale of 1:1. Why do you need a layout at 1:100? Link to comment Share on other sites More sharing options...
lbuttery Posted April 12, 2017 Share Posted April 12, 2017 Glenn: I'm confused (as usual) when we use "send to layout" don't we choose the scale then - usually 1/4" ??? Lew Link to comment Share on other sites More sharing options...
tommy1 Posted April 12, 2017 Share Posted April 12, 2017 Lew, Your Drawing Scale in the "Drawing Sheet Setup" for the layout should be set to 1" =1" so that when you send a plan view or anything else to the layout at a particular scale, it will be correct. Link to comment Share on other sites More sharing options...
lbuttery Posted April 12, 2017 Share Posted April 12, 2017 Tommy: I guess mine have always been 1:1 never had an issue with them must be 1:1 OOB Lew Link to comment Share on other sites More sharing options...
tommy1 Posted April 12, 2017 Share Posted April 12, 2017 By default, it is 1" to 1" for the layout. Link to comment Share on other sites More sharing options...
