Gap between floor in 3D
JamieMiller
2 hours ago, JamieMiller said:
I have been trying to get rid of this gap between the floors in the 3D view. I'm sure it's something simple that I'm missing. Please help.
Thanks,
Jamie
After you build the floor framing, the gap will fill.
  • Downvote 2
The gap may fill - but it may also fill with the floor framing material - depending on you wall definition.
In this case, it looks like the floor framing should stop at some wall layer inboard of the outer stone layer.
My best guess is that it is your Build Platform To Exterior of Layer setting.
You probably have it set to the outside wall layer.
Try changing it to the wall's main layer or something inside the outer stone layer.
Once this is set correctly building the floor framing or not shouldn't make any difference.
It is hard to be more specific without seeing your wall definition details.
  • Upvote 3
Glenn, Bro, You did it :) That wasn't the only issue however. I had all the exterior wall layers listed as main layers in my wall def lmao... I changed it so the main wall layer was the stud wall and bam fixed :D
Thanks for all that tried to help me.
Jamie
