JamieMiller Posted April 9, 2017 Share Posted April 9, 2017 I have been trying to get rid of this gap between the floors in the 3D view. I'm sure it's something simple that I'm missing. Please help. Thanks, Jamie Link to comment Share on other sites More sharing options...
Chopsaw Posted April 9, 2017 Share Posted April 9, 2017 Jamie, Here is some discussion on your topic that may or may not help but is worth reading: Link to comment Share on other sites More sharing options...
JJohnson Posted April 9, 2017 Share Posted April 9, 2017 2 hours ago, JamieMiller said: I have been trying to get rid of this gap between the floors in the 3D view. I'm sure it's something simple that I'm missing. Please help. Thanks, Jamie After you build the floor framing, the gap will fill. 1 2 Link to comment Share on other sites More sharing options...
glennw Posted April 9, 2017 Share Posted April 9, 2017 The gap may fill - but it may also fill with the floor framing material - depending on you wall definition. In this case, it looks like the floor framing should stop at some wall layer inboard of the outer stone layer. My best guess is that it is your Build Platform To Exterior of Layer setting. You probably have it set to the outside wall layer. Try changing it to the wall's main layer or something inside the outer stone layer. Once this is set correctly building the floor framing or not shouldn't make any difference. It is hard to be more specific without seeing your wall definition details. 3 Link to comment Share on other sites More sharing options...
JamieMiller Posted April 9, 2017 Author Share Posted April 9, 2017 Glenn, Bro, You did it That wasn't the only issue however. I had all the exterior wall layers listed as main layers in my wall def lmao... I changed it so the main wall layer was the stud wall and bam fixed Thanks for all that tried to help me. Jamie Link to comment Share on other sites More sharing options...
