Chief16Designer Posted April 8, 2017 Share Posted April 8, 2017 What would be causing the roof not to rebuild? All rooms are closed Thanks in Advance X6 2_nd_Floor_roof_does_not_rebuild__X6.plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 8, 2017 Share Posted April 8, 2017 33 minutes ago, Chief16Designer said: What would be causing the roof not to rebuild? Auto Rebuild Roofs isn't toggled on... 1 Link to comment Share on other sites More sharing options...
javatom Posted April 8, 2017 Share Posted April 8, 2017 Maybe a little manual roof editing is in order. 1 Link to comment Share on other sites More sharing options...
Chief16Designer Posted April 8, 2017 Author Share Posted April 8, 2017 Auto rebuild roof is On Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 8, 2017 Share Posted April 8, 2017 With such a geometrically complicated roof system, I use auto-build roofs and then simplify the roof lines manually. You should also consider doing that as well in this case. Auto Build roofs for me is usually just a starting point. I am smarter and more experienced that any software running on settings, you are too. DJP 1 Link to comment Share on other sites More sharing options...
Chief16Designer Posted April 8, 2017 Author Share Posted April 8, 2017 16 minutes ago, DavidJPotter said: With such a geometrically complicated roof system, I use auto-build roofs and then simplify the roof lines manually. You should also consider doing that as well in this case. Auto Build roofs for me is usually just a starting point. I am smarter and more experienced that any software running on settings, you are too. DJP Yes I do the same but the plan is still in working progress thank you +1 Link to comment Share on other sites More sharing options...
Chief16Designer Posted April 9, 2017 Author Share Posted April 9, 2017 2 hours ago, solver said: It's off in the plan you posted. Here is what I get after a roof build. I'd start by setting your platform defaults -- ceiling heights etc, for each floor. Resetting everything to the defaults, and then making changes as needed. Thank you +1 Link to comment Share on other sites More sharing options...
