Adjusting the length of curtains
Hi,
I am new to Chef Architect so please forgive me if my question is super silly. I've created a room, added window treatments but have no idea how to make my curtains to touch the floor. When I go to window treatments options there is nothing to adjust it. I would be very happy if someone could help me with that.
Thanks,
Thank you so much, Solver. I was putting 0" there but forgot to remove (D) so nothing was happening!
Is it also possible to adjust the width of the curtain rod so it would be wider than a window?
I really appreciate your help :)
I don't think so. You might check the 3D Warehouse for a symbol that would work, or make a symbol from the existing curtains if you like them.
  • Upvote 2
Quote
You can't do this if you make the curtain part of the window through the treatments panel on the Window Specification dialog.
You can take any of the curtains from the library and just place them directly into the plan.  You can then resize them and position them however you like.  The only thing you really lose by doing this is that if you move or resize the window, the curtain will not move or resize with it.
  • Downvote 1
Thank you, Dermot! I tried that option earlier but didn't like that it also affected the size of the window. Default setting doesn't bother me so much, I just thought that there might be some additional options I don't know about.
This is not entirely true.  Not a super detailed explanation but here's basically how to do it.  Pretty easy...
windows with curtains using windows treatment in the windows dbx is possible.
 you can resize with windows in window dbx, can extend top, bottom and sides of window. This is all doable in the windows treatment panel of windows dbx. Once you set up your desired look you are able to copy and paste any were in plan, though the initial set up of the window could be tricky, point is that you need to create a milwork symbol that fits the desired position by tweaking the symbol orrigion in symbol dbx. Advantageous also,  since it automatically  fits  on curved walls easily.
Here is the test plan including the .calibz symbol.
Curtains extinding sides of windows and flexible height.plan
windows and curtains with flexible dimensions..calibz
  • 3 years later...
How do you copy the curtain to your user library? I need step by step because it's not working for me. Please help
The same way as you would copy/paste files in almost any other environment:
  • Select the item and either right click>copy or hit Control+C
  • Navigate to the desired folder and either right click>paste or hit Control+V
    29490
    smarthomes
    smarthomes
  • Similar Content
    • By Bouquet
      I just saw the newest bonus catalogs - love them!  But I'm still waiting to be able to add a single drapery panel to my plans.  The current pair of panels is awkward and pretty useless.  I've written to request that a single panel be including in interior accessories folder (and received a nice reply), but it's still not there.  C'mon, it would be a GREAT help to designers!
