videte Posted March 29, 2017 Share Posted March 29, 2017 Hi, I am new to Chef Architect so please forgive me if my question is super silly. I've created a room, added window treatments but have no idea how to make my curtains to touch the floor. When I go to window treatments options there is nothing to adjust it. I would be very happy if someone could help me with that. Thanks, Link to comment Share on other sites More sharing options...
videte Posted March 29, 2017 Author Share Posted March 29, 2017 Thank you so much, Solver. I was putting 0" there but forgot to remove (D) so nothing was happening! Is it also possible to adjust the width of the curtain rod so it would be wider than a window? I really appreciate your help Link to comment Share on other sites More sharing options...
videte Posted March 30, 2017 Author Share Posted March 30, 2017 Thank you, Solver! Link to comment Share on other sites More sharing options...
Dermot Posted March 30, 2017 Share Posted March 30, 2017 Quote Is it also possible to adjust the width of the curtain rod so it would be wider than a window? You can't do this if you make the curtain part of the window through the treatments panel on the Window Specification dialog. You can take any of the curtains from the library and just place them directly into the plan. You can then resize them and position them however you like. The only thing you really lose by doing this is that if you move or resize the window, the curtain will not move or resize with it. 1 1 Link to comment Share on other sites More sharing options...
videte Posted March 30, 2017 Author Share Posted March 30, 2017 4 hours ago, Dermot said: The only thing you really lose by doing this is that if you move or resize the window, the curtain will not move or resize with it. Thank you, Dermot! I tried that option earlier but didn't like that it also affected the size of the window. Default setting doesn't bother me so much, I just thought that there might be some additional options I don't know about. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 31, 2017 Share Posted March 31, 2017 7 hours ago, Dermot said: You can't do this if you make the curtain part of the window through the treatments panel on the Window Specification dialog. This is not entirely true. Not a super detailed explanation but here's basically how to do it. Pretty easy... Link to comment Share on other sites More sharing options...
yusuf-333 Posted March 31, 2017 Share Posted March 31, 2017 windows with curtains using windows treatment in the windows dbx is possible. you can resize with windows in window dbx, can extend top, bottom and sides of window. This is all doable in the windows treatment panel of windows dbx. Once you set up your desired look you are able to copy and paste any were in plan, though the initial set up of the window could be tricky, point is that you need to create a milwork symbol that fits the desired position by tweaking the symbol orrigion in symbol dbx. Advantageous also, since it automatically fits on curved walls easily. Here is the test plan including the .calibz symbol. Curtains extinding sides of windows and flexible height.plan windows and curtains with flexible dimensions..calibz Link to comment Share on other sites More sharing options...
DH7777 Posted March 8, 2021 Share Posted March 8, 2021 On 3/30/2017 at 7:02 PM, Alaskan_Son said: This is not entirely true. Not a super detailed explanation but here's basically how to do it. Pretty easy... How do you copy the curtain to your user library? I need step by step because it's not working for me. Please help Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 8, 2021 Share Posted March 8, 2021 34 minutes ago, DH7777 said: How do you copy the curtain to your user library? The same way as you would copy/paste files in almost any other environment: Select the item and either right click>copy or hit Control+C Navigate to the desired folder and either right click>paste or hit Control+V Link to comment Share on other sites More sharing options...
DH7777 Posted March 8, 2021 Share Posted March 8, 2021 Got it Thanks! Link to comment Share on other sites More sharing options...
