Fill Pattern - Checker plate
RobWhite
On 3/26/2017 at 11:04 AM, Northriver said:
Here is all the fill patterns that come with chief.
Chief hatch patterns.pdf
On 3/26/2017 at 1:57 PM, DRAWZILLA said:
here is a pdf the shows all the Chief patterns, forgot where I got it.
Fill Hatch Patterns Cheat Sheets.pdf
Where are these hatch patterns located?  I've never seen these lists before this thread.  I can only find about 40 hatch patterns that come with Chief.  There seems to be 6 or 7 times that many on the lists above.  Can anyone point me to where they are located?
19 minutes ago, solver said:
Each of these pattern files contains multiple patterns. They are text files if you want to look inside.
Whoa!  I didn't realize we had all those.  Thanks Eric.  I had only ever used what was in that first pattern file.
I've seen those files but I guess I just assumed those were all names of the individual patterns already listed in the standard drop-downs.  This is the type of thing that is very surprising to learn that I have been missing out on this long.  Thanks again Eric!!
