luckyudesign Posted February 28, 2017 Share Posted February 28, 2017 What causes toolbars to randomly disappear? This evening working on X8 I exited out of program and when I opened it back up, they were gone. Can't find them. Installed X9, not there either. Any ideas? Link to comment Share on other sites More sharing options...
luckyudesign Posted February 28, 2017 Author Share Posted February 28, 2017 I go to Tools, Customize Toolbars, and I get a warning "Attempting to load an invalid toolbar: ID 2001". So when i get throught that and try to import default toolbar warning says "Error loading toolbar configuration". I'm going to send in a ticket but if someone knows a quick fix, I'd appreciate it. Link to comment Share on other sites More sharing options...
glennw Posted February 28, 2017 Share Posted February 28, 2017 You could try Preferences...Reset Options...Reset Toolbars. This will load Chief's default toolbars and you will loose any customisation. You will probably have to restart Chief after doing the above. Link to comment Share on other sites More sharing options...
luckyudesign Posted February 28, 2017 Author Share Posted February 28, 2017 Thanks, Glenn. That worked. I had hit the "reset toolbar" in the toolbar config tab and it didn't work but this did. Thanks again! Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 28, 2017 Share Posted February 28, 2017 You can also just delete the toolbar file in the data location and it will automatically re-build if needed, but only at last resort. Link to comment Share on other sites More sharing options...
