capitaldesigns Posted February 13, 2017 Share Posted February 13, 2017 I am entering a house that I measure last week. The toilet room in the master bathroom has a 45 degree wall with a 2'-4"x6'-8" door. The interior dimension of the 45 degree wall is 2'-10". CA will not let me insert the 2'-4" door into this wall. It reduces the size of the door down to 2'-0" wide. The only way I can place the 2'-4" wide door in this wall is to reduce the casing down to 1.5" wide. The problem is that when I reduce the casing it does it on both side of the door. Is there a way to have the casings on one side of the door be different size than the other side like we can do with exterior doors ? I measured 3.5" distance from the edge of the casing next to the door opening to the corner of the 45 degree wall. Why will CA not let me have a 3" casing since there is 3.5" of wall to attach the casing ? One last unrelated question. I just viewed a video that Alaskan Son did regarding making custom columns. Is there a way to tag these videos and/or topics for future reference ? Thanks, Mike Link to comment Share on other sites More sharing options...
justmejerry Posted February 13, 2017 Share Posted February 13, 2017 Mike have you got "ignore casing for opening" checked? Subscribe to his You tube channel and you can watch videos at your convenience. Link to comment Share on other sites More sharing options...
capitaldesigns Posted February 13, 2017 Author Share Posted February 13, 2017 Thanks. I was looking under door defaults. Both solutions for this door. Thanks, Mike Link to comment Share on other sites More sharing options...
BeachHouse1 Posted June 15, 2021 Share Posted June 15, 2021 On 2/12/2017 at 9:38 PM, solver said: Where do you find this? Found it. You would expect it to be on the Casing Tab, But it's in the General Tab. Link to comment Share on other sites More sharing options...
glennw Posted June 15, 2021 Share Posted June 15, 2021 It's probably on the General tab because it relates to the casings, lintels and materials, not just the casings. Link to comment Share on other sites More sharing options...
