Camera Field Of View
MPDesign
A question about the visual accuracy of the 55 degree setting.
Is this default what you would see in your "eye" point of view?  if you were standing there?
I have a client that wants to see the house from 100 feet out in front.
Is the view generated with full camera and using a marker on the terrain in plan view visually accurate?
Has anyone ever tested this? I have to assume it has.
Thank you for your insite. :)
Perception of what is seen varies from person to person. I think the angle is close to what you would see assuming you had blinders on and could only see what was in the scene. Viewing 3D scenes in a 2D medium is not something that everyone does equally well so results will vary. You can adjust the field of view angle if needed for your customer.
