automatic load bearing wall grade beam in foundation
DianeP
Is there a way to have the footing you can add on a wall dbx show on the foundation instead of the 1st floor.  This seems to have been something discussed in 2001-2003 in my google search but there weren't any answers that didn't require drawing it in manually.  Has there been any developments in Chief regarding this issue since then?  I am currently on X8.   Thanks
Thanks for you answer Glenn,  Unfortuately, I can't find this option.  I click on the wall and the dialog box gives me the option to make it a foundation wall under the General Tab.  Alternatively, on the Foundation tab I can make it a foundation wall with or without slab footing.  All options show up on the same level as the original wall (1st floor).  Any place else for me to look?
