Larry_Sweeney Posted February 9, 2017 Share Posted February 9, 2017 Is there a way to make a wall type showing 1x3 furring strips applied horizontal to the studs that shows in a cross section? Thank you in advance for your time and advice. Link to comment Share on other sites More sharing options...
Evolution Posted February 9, 2017 Share Posted February 9, 2017 I'm not the expert here, but I've never seen that capability in X8. Don't think it is in X9 either. Based on what I do know, you most likely will have to address it with notes, and add it in cad details. You can make a wall type, adding it as a layer, I don't think however; that you can note in the wall definition what it actually is, although you can add it in the "wall type" box as "4" (whatever thickness the wall should be) exterior/interior whichever, wall with horizontal furring at thus and thus, and use that in your wall types schedules (if you do one). Again, though, you could add a balloon on your floor plan of the particular wall(s) that will have this Horizontal furring, and explain what it is supposed to be/do, I would think. Link to comment Share on other sites More sharing options...
Chopsaw Posted February 9, 2017 Share Posted February 9, 2017 Here is some discussion on current workarounds from a previous thread: Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted February 10, 2017 Author Share Posted February 10, 2017 Bob & Chopsaw..............................Cad details is the way I went. In the wall definition I just left a 3/4" airspace and then in cross sections drew in cross boxes to represent the furring. Thanks for your time and advice. Have a great day. Link to comment Share on other sites More sharing options...
