Francois Posted January 27, 2017 Share Posted January 27, 2017 http://energycodeace.com/?utm_source=new+year%2C+new+code%2C+new+site+-+sent+012617&utm_campaign=new+year%2C+new+site+sent+012617&utm_medium=email New code , Tools and Application guides Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 27, 2017 Share Posted January 27, 2017 thanks, lots of good info. Link to comment Share on other sites More sharing options...
Gawdzira Posted January 28, 2017 Share Posted January 28, 2017 Thanks for the link. Here is one to add to the notes: Vacancy Sensors Section 150.0(k)Vacancy sensors are required in many residential spaces. A minimum of one luminaire in each of the following spaces must be controlled with a vacancy sensor: bathrooms, garages, laundry rooms and utility rooms Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 28, 2017 Share Posted January 28, 2017 13 hours ago, Gawdzira said: Thanks for the link. Here is one to add to the notes: Vacancy Sensors Section 150.0(k)Vacancy sensors are required in many residential spaces. A minimum of one luminaire in each of the following spaces must be controlled with a vacancy sensor: bathrooms, garages, laundry rooms and utility rooms Yep, they used to call it an Occupancy sensor's, now it's Vacancy sensor's. Of course Chief doesn't have any of those, so you need to change the cad block and save it to your lib. Link to comment Share on other sites More sharing options...
