ACADuser Posted January 24, 2017 Share Posted January 24, 2017 I would like to toggle between "Select Crossing" and "Select Contained" with a Hot Key. Is that doable? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 24, 2017 Share Posted January 24, 2017 Link to comment Share on other sites More sharing options...
ACADuser Posted January 24, 2017 Author Share Posted January 24, 2017 You know your getting old when you forget the meaningful conversation you had in January. Well the SC keys are close together but the SI requires two hands or awkward left hand jump. Just complaining, sorry. Thanks for the reminder. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 24, 2017 Share Posted January 24, 2017 You bet. You can assign any hotkeys you want. Those are just one example. Link to comment Share on other sites More sharing options...
brian-sdesign Posted January 24, 2017 Share Posted January 24, 2017 Would be nice if this worked similar to autocad. If you click then pull left it's a crossing box, click and pull right it's a selection box Link to comment Share on other sites More sharing options...
glennw Posted January 24, 2017 Share Posted January 24, 2017 4 hours ago, ACADuser said: You know your getting old when you forget the meaningful conversation you had in January. Well the SC keys are close together but the SI requires two hands or awkward left hand jump. Just complaining, sorry. Thanks for the reminder. Alan, Do you realise that those hotkeys can be sequential and not simultaneous? (you can do it either way) ie, you can use S and I in sequence, not at the same time. Link to comment Share on other sites More sharing options...
ACADuser Posted January 24, 2017 Author Share Posted January 24, 2017 yes sir I do. I just want a toggle like press F20 to switch modes & F20 again to switch back. I go along doing my business but at times the lack of a better selection method gets to me and I go off on a search to fix this aggravation that I suppress daily. The Click & drag is the other one that drives me nuts. Oh I live with it but I don't have to like it. Link to comment Share on other sites More sharing options...
