Modeling different foundation conditions in same room
spbreslin
Make it slab on grade on main floor, then add the 2 walls on floor 0 under the slab. use a section camera to adjust the height of the walls.
Actually it may be easier to, make it a basement room with the stem wall height that you want the 2 walls to be, then make the other 2 walls invisible.
14 hours ago, spbreslin said:
I am working on a situation in a garage where I have a stem wall footing on two sides and slab on grade footing on the other two. Any tips on how to get this to work in Chief? I haven't had any luck so far.
It would help to see more specifically what exactly your situation is such as the shape of the structure, how and where the walls meet, the elevations of your garage floor and stem walls, etc.
The best way to accomplish what you're looking for may vary depending on some of the above details.
