Enlarged Plans - Done Manually?
Anna_Gorres
> I want to do an enlarged plan of the kitchen.
I do not know what that means... Your plans are always in the live scale, when you send data to layout, in the layout  you "enlarge" by specifying 1/2" - 1' or 1"  - 1'.
If you want elevation cameras to show a wall or kitchen island - you create them.
Do you mean that you want a separate layout box that contains only the kitchen that is of a different scale than the main floor plan?
If so- send a separate view to layout at a larger scale - on it's own layer set maybe?
Then crop the layout box to fit.
