Anna_Gorres Posted January 20, 2017 Share Posted January 20, 2017 Hello All, I want to do an enlarged plan of the kitchen. I do not see a camera view for this. Do I have to do this manually? I feel like this would get quite 'muddy'. Your help is always appreciated! Anna Link to comment Share on other sites More sharing options...
DavidJames Posted January 20, 2017 Share Posted January 20, 2017 What do you mean by an enlarged plan? Are you wanting a larger scale? A zoomed-in perspective? Link to comment Share on other sites More sharing options...
BrownTiger Posted January 20, 2017 Share Posted January 20, 2017 > I want to do an enlarged plan of the kitchen. I do not know what that means... Your plans are always in the live scale, when you send data to layout, in the layout you "enlarge" by specifying 1/2" - 1' or 1" - 1'. If you want elevation cameras to show a wall or kitchen island - you create them. Link to comment Share on other sites More sharing options...
RL-inc Posted January 20, 2017 Share Posted January 20, 2017 Do you mean that you want a separate layout box that contains only the kitchen that is of a different scale than the main floor plan? If so- send a separate view to layout at a larger scale - on it's own layer set maybe? Then crop the layout box to fit. Link to comment Share on other sites More sharing options...
Anna_Gorres Posted January 23, 2017 Author Share Posted January 23, 2017 Rob, yes, that is what I am referring to. I will try that. I was hoping there would be automatic call out markets and what not. I will have to create my own. Thank you much! Anna Link to comment Share on other sites More sharing options...
digitecht Posted January 24, 2017 Share Posted January 24, 2017 when you send a plan to layout, you scale it up.. instead of 1:100, you rescale it to 1:50 or whatever you want. But then, you should have a layerset/Annoset with larger text, dim etc at a height to suit... Frank Link to comment Share on other sites More sharing options...
