chansman Posted June 14, 2014 Share Posted June 14, 2014 I must be missing a simple setting but how in the world do i get the exterior surfaces of my foundation wall align with the exterior surface of my main floor brick wall? Link to comment Share on other sites More sharing options...
dshall Posted June 14, 2014 Share Posted June 14, 2014 Add 7/16" to the first wall between the brick and concrete Link to comment Share on other sites More sharing options...
chansman Posted June 14, 2014 Author Share Posted June 14, 2014 Like this? Link to comment Share on other sites More sharing options...
Kbird1 Posted June 14, 2014 Share Posted June 14, 2014 yes I think that's what he meant. did it work ? normally the Wall's Main Layers align which can throw things out sometimes too ,depending on what is set as the main layer. Link to comment Share on other sites More sharing options...
glennw Posted June 15, 2014 Share Posted June 15, 2014 Or... Preferences...Edit...Behaviors...Primary Movement Method...Orthogonal Alt+Q...Resize About...Outer Surface Turn on Reference Display Turn on On Object snap Select wall and drag and snap to outside of referenced wall. Link to comment Share on other sites More sharing options...
