TheKitchenAbode Posted January 4, 2017 Share Posted January 4, 2017 I can't get my cabinets to bump/push with each other when moving them vertically. Works fine for all horizontal movements but when moving vertically they will only bump/push when contacting a wall or ceiling plane, not with each other. Is this normal behavior? Running X8. Thanks, Graham Link to comment Share on other sites More sharing options...
dshall Posted January 4, 2017 Share Posted January 4, 2017 4 minutes ago, TheKitchenAbode said: I can't get my cabinets to bump/push with each other when moving them vertically. Works fine for all horizontal movements but when moving vertically they will only bump/push when contacting a wall or ceiling plane, not with each other. Is this normal behavior? Running X8. Thanks, Graham I was able to open a new plan, I put in base cab, and then put in upper cab, I then did a back clip cross section and moved base cab up and it bumped into upper cab, I then tried to move upper cab down to lower cab and it bumped. My cabinets bump when I am moving in vertical direction. It works for me. X9 Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 4, 2017 Author Share Posted January 4, 2017 Thanks Scott - Just tried that and my upper cabinet just passes through the base cabinet when moving vertically as if the bump/push is turned off, which it is not as it works on horizontal moves. Graham Link to comment Share on other sites More sharing options...
MPDesign Posted January 4, 2017 Share Posted January 4, 2017 Not working for me. using X8 Link to comment Share on other sites More sharing options...
