Layer settings for floor plan and framing plan
capitaldesigns
I am having a problem with objects I drew on the floor plan showing up on the framing plan. I have several callouts on the floor plan with a line with arrow pointing to an object in the plan.
When I switch to the framing annotation set the lines with arrows show up as well. The floor plan notes do not show up in the framing set. The notes were automatically given
a different layer name for the notes added to the floor plan v. notes added to the framing plan. How do I get the lines with arrows to do the same ? The layer name they were given was
CAD default.
Thanks,
Mike
Your anno sets and defaults are not set properly. You need to select the text and change the layer so that it can be hidden in the framing anno set.
For instance I have layers called
text, floor plan
text, foundation
text, framing
text, electrical
etc....
That way specific text shows where it should.
