HumbleChief Posted December 30, 2016 Share Posted December 30, 2016 Old, old, topic and it seems I've just gotten used to a bunch of unused and unwanted Layers from years of creating them and thought I might clean up my Layer mess but can't delete unused Layers that I have created. Is there a trick or are we stuck with those unused Layers forever? These are not Chief system layers, but custom layers I've created and are no longer needed nor 'used' in any plan views either. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 30, 2016 Share Posted December 30, 2016 Larry, There are 2 sneaky reason I can think of off the top of my head that would cause a layer to be UN-deletable. 1. The layer is being used in one of your CAD blocks. To fix this you might have to go into CAD Block Management and either Purge all unused CAD Blocks or at least purge the ones that are using those layers. 2. You have a default setting somewhere that is using that layer. This is probably the hardest one to track down unless you know exactly where it is. Link to comment Share on other sites More sharing options...
HumbleChief Posted December 30, 2016 Author Share Posted December 30, 2016 Yeah thanks Michael, Those details are probably why I give up each time I try. SIGH... Link to comment Share on other sites More sharing options...
ACVNarch Posted March 1, 2024 Share Posted March 1, 2024 I know I'm necroposting, but I had a bunch of layers in my template that I could not find for the life of me... I finally realized that I could simply "merge" them all into a user layer that I actually was using. In fact, it's possible to merge user layers into system layers, you just need to pick them in the right order. Just an option for those of us looking to clean up our templates. 2 Link to comment Share on other sites More sharing options...
tundra_dweller Posted March 1, 2024 Share Posted March 1, 2024 1 hour ago, ACVNarch said: necroposting Upvoting solely for the use of the term "necroposting". And I've never noticed the "merge" function before, thanks! Link to comment Share on other sites More sharing options...
