half post at wall
wncbw7
6 minutes ago, ChiefGrego said:
Curious,  why did you create this wall without the drywall
That would be the railing wall  ( Interior Railing,ND )  No Drywall.  That is essentially my outdoor Railing wall which never needs drywall and does not need to display the extra layers also it is a little simpler to keep track of the width  when modifying for offsets etc.  Also can be used for interior where the drywall layer is causing display issues for instance a railing mounted on an exposed beam or stringer etc.  Give it a try.B)
