dshall Posted June 12, 2014 Share Posted June 12, 2014 I have an exterior set of stairs in front yard going up to a second floor deck. This is a private residence. Minimum tread is 10" if that includes a 1" nosing, if no nosing the minimum tread depth is 11"......... for stairs inside the house For public stairs the minimum tread depth is 11"... period, cannot be 10" even with nosing. Would you consider my stairs public or private, and if private, should I be able to get away with a 10" tread if I have a 1" nosing. The stairs will be open riser so I get the nosing by default. Thanks for the help guys. (CALIFORNIA RESIDENTIAL CODE) Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 12, 2014 Share Posted June 12, 2014 I would say private (single family) Link to comment Share on other sites More sharing options...
rlackore Posted June 12, 2014 Share Posted June 12, 2014 Private if it's a single-family dwelling on a privately owned lot (but I don't live in California). Link to comment Share on other sites More sharing options...
Richard_Morrison Posted June 13, 2014 Share Posted June 13, 2014 Scott, Just FYI, unless the stairs are going to be 30" or less in height, open risers are no longer permitted. Check the Code. Link to comment Share on other sites More sharing options...
dshall Posted June 13, 2014 Author Share Posted June 13, 2014 On 6/13/2014 at 10:40 PM, Richard_Morrison said: Scott, Just FYI, unless the stairs are going to be 30" or less in height, open risers are no longer permitted. Check the Code. That's what I thought, but I was just reading the code, and it said they were allowed as long as a 4" sphere could not pass thru. I will double check. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 14, 2014 Share Posted June 14, 2014 her is the code in Cali. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 14, 2014 Share Posted June 14, 2014 I read the code to say if the stairs are 30" or less then you can have open risers and open risers are permitted with the sphere test Link to comment Share on other sites More sharing options...
Richard_Morrison Posted June 14, 2014 Share Posted June 14, 2014 On 6/14/2014 at 12:07 AM, DRAWZILLA said: I read the code to say if the stairs are 30" or less then you can have open risers and open risers are permitted with the sphere test Well, if you are using 2X treads, then you have to kind of fill in the gap unless the steps have a riser height of less than 5.5", otherwise you don't pass the sphere test. So you need SOMETHING on your riser, but I would be afraid of using a partially closed riser. Seems like it would be a good way to get a toe caught in there during a fall. If the stairs have a total height of less than 30", then you can use open risers, of course. Link to comment Share on other sites More sharing options...
dshall Posted June 14, 2014 Author Share Posted June 14, 2014 On 6/14/2014 at 12:07 AM, DRAWZILLA said: I read the code to say if the stairs are 30" or less then you can have openrisers and open risers are permitted with the sphere test Ha! Thanks P., I thought that is what I read. I can have open risers if I pass the sphere test. It is so important to read and understand the ifs ands or buts. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 14, 2014 Share Posted June 14, 2014 On 6/14/2014 at 12:58 AM, Richard_Morrison said: Well, if you are using 2X treads, then you have to kind of fill in the gap unless the steps have a riser height of less than 5.5", otherwise you don't pass the sphere test. So you need SOMETHING on your riser, but I would be afraid of using a partially closed riser. Seems like it would be a good way to get a toe caught in there during a fall. If the stairs have a total height of less than 30", then you can use open risers, of course. I would put the 4" or so blocking on the top of the tread so it would stop your toe. On the bottom could be a toe catcher. Link to comment Share on other sites More sharing options...
