plaster over brick material
brian-sdesign
Or if you want something custom define a brick wall with a finish layer of stucco and move the brick to the main layer, then use a wall material region or custom backsplash set to " Cut Finish Layers of Parent Object"  and then delete all the material layers to show your brick.
