Dimension Default-locate-wall-none still does
MarkMc
Trying to set a dimension default that only locates base cabinets but does not locate wall. Checked "none" for "walls" in the default DBX but it still locates whatever is listed in "wall options" which doesn't have a choice of "none"
Is this somewhere else?
Thanks for bringing this up.  I agree with you,  I do not understand why the wall is also dimensioned.  I suppose I have just lived with it,  but it should not be the case.  Would you mind reporting it?
Mark,
Try locking the Wall Layers in your Layer Set.  I find that the Walls can still apparently be located but the dimensions only attach to the cabinets.  They seem to still find the Wall Dimension Layer but not the Interior Wall Faces.  I agree that this is a bug and should be reported.
