Terrain Perimeter lengths
cjanderson66
It's worth remembering that you can easily add a dimension for a line with no extensions, and put it on a layer with a white color, in any newly created dimension style you want (the dimension text should be defined as black, though, for the style; if "by layer" it will turn white and disappear), and even add the bearing as leading text. When you stretch the line, the dimension will change accurately, although the bearing, which is just text, won't. But this will let you have as many dimension styles in a single view as you want, and you can mix and match text sizes, number of decimal points, etc.
