JECORMIER Posted December 9, 2016 Share Posted December 9, 2016 Hey everyone- I've been wondering how to add 1x4 p.t. (3/4"x3 1/2") @16" o.c. vertical furr strips as a layer to my exterior walls to provide a rain screen under my hardie board siding. I don't know exactly how to set up the layer with individual strips at 16" o.c.. When I set up the layer it gives me the option of material and thickness but only as a continuous sheathing, not 1x4 vertical strips. I'm sure someone has done this and I'm just missing the obvious answer. See photo for example... Thanks for your help in advance!!! J Link to comment Share on other sites More sharing options...
joey_martin Posted December 9, 2016 Share Posted December 9, 2016 You will most likely need to set it up to be a framing layer. Link to comment Share on other sites More sharing options...
joey_martin Posted December 9, 2016 Share Posted December 9, 2016 Open the wall type and add the 3/4" layer where you want it, I placed it on top of the paper, and set the material to fri framing 16" or 24" o.c.. You should get what you need. Link to comment Share on other sites More sharing options...
JECORMIER Posted December 9, 2016 Author Share Posted December 9, 2016 perfect! thank you Link to comment Share on other sites More sharing options...
JJohnson Posted December 10, 2016 Share Posted December 10, 2016 6 hours ago, JECORMIER said: Hey everyone- I've been wondering how to add 1x4 p.t. (3/4"x3 1/2") @16" o.c. vertical furr strips as a layer to my exterior walls to provide a rain screen under my hardie board siding. I don't know exactly how to set up the layer with individual strips at 16" o.c.. When I set up the layer it gives me the option of material and thickness but only as a continuous sheathing, not 1x4 vertical strips. I'm sure someone has done this and I'm just missing the obvious answer. See photo for example... Thanks for your help in advance!!! J JE, I have not seen that before. How does that function as a 'rain screen' ? Link to comment Share on other sites More sharing options...
jcaffee Posted December 10, 2016 Share Posted December 10, 2016 Jere... http://www.dupont.com/products-and-services/construction-materials/building-envelope-systems/brands/water-barrier-systems/products/rainvent-batten-furring-strips.html Link to comment Share on other sites More sharing options...
JJohnson Posted December 10, 2016 Share Posted December 10, 2016 7 hours ago, jcaffee said: Jere... http://www.dupont.com/products-and-services/construction-materials/building-envelope-systems/brands/water-barrier-systems/products/rainvent-batten-furring-strips.html Thank you for the link. I had not heard of this, but I can see it being a plus in rainy climates. Should have been called 'rain vent' rather than 'rain screen' I guess. We do not see it here in Nor California, as we have an extended dry season, and things can dry out nicely. The rain free early fall here lets wine grapes avoid the dreaded cluster rot that will set in when bunches get wet. . .. .. Link to comment Share on other sites More sharing options...
