shanecarman Posted December 1, 2016 Share Posted December 1, 2016 Hello, I am working on creating a lodge. I have auto roofs on and it has been working great. I added a new, small area for elevators on all three floors. Now on a random, unchanged area, I keep getting error messages about roof ridges. I have never seen these errors before and now the roof looks insane and is all over the terrain. I can't locate the tool mentioned in the error message either. I have attached the file zipped and in a dropbox link due to its size. The area it is circling is on the right side of the plan on the third floor. I would highly appreciate any advice. https://www.dropbox.com/s/4lnb3a96pr53xrl/Family%20Ranch%20Lodge%20-%20Ocean%20or%20Lake%20views.zip?dl=0 Thank you! Shane Link to comment Share on other sites More sharing options...
javatom Posted December 1, 2016 Share Posted December 1, 2016 You can always lock the roof planes if they looked good at one point before they started the odd behavior. Link to comment Share on other sites More sharing options...
Mark3D Posted December 2, 2016 Share Posted December 2, 2016 I got your roof working i had go to edit menu choose reset defaults select all all floor after the the is working it might mess with some of your settings just fix and you should be good 1 Link to comment Share on other sites More sharing options...
glennw Posted December 2, 2016 Share Posted December 2, 2016 Shane, For starters, your floor/ceiling settings on the 2nd and 3rd floor elevators appear to be incorrect. They should probably changed to Default - I assume that would be correct. This is the main cause of the auto roof problems. Change those settings and you will see a huge difference. There is still an error message saying "Cannot Produce a Roof Plane" which I don't have time to troubleshoot now as I am off to bed. If I get time in the morning, I will have another look. This is doing pretty much what Mark was doing in his post - I just narrowed it down to the floor/ceiling settings in the elevators. 1 Link to comment Share on other sites More sharing options...
shanecarman Posted December 8, 2016 Author Share Posted December 8, 2016 On 12/2/2016 at 7:23 AM, glennw said: Shane, For starters, your floor/ceiling settings on the 2nd and 3rd floor elevators appear to be incorrect. They should probably changed to Default - I assume that would be correct. This is the main cause of the auto roof problems. Change those settings and you will see a huge difference. There is still an error message saying "Cannot Produce a Roof Plane" which I don't have time to troubleshoot now as I am off to bed. If I get time in the morning, I will have another look. This is doing pretty much what Mark was doing in his post - I just narrowed it down to the floor/ceiling settings in the elevators. Thank you so much! This worked. Link to comment Share on other sites More sharing options...
