corner window trouble
amathews
  • 1 year later...
Picking up on this older thread, I'm trying to place nanawalls on two walls, one of them curved.  Using the pass-thru window as the initial work-around to create the opening, it seems to work fine for walls that are orthogonal to each other.  But, I'm having difficulty getting the required behaviour for a corner that has one slightly curved wall.  That is, I'd like to remove the corner portion of the wall.
Any ideas on how to get this to work?  An example is attached.
Corner windows.plan
