amathews 0 Posted November 13, 2016 Can't get 2 fixed windows to become a corner window. They are the same height. These are transom windows above corner windows below. I am using version X8 Share this post Link to post Share on other sites
DavidJPotter 323 Posted November 14, 2016 What works for me is simple persistence, not much of a tip but is all I have to offer, just don't give up until you get a product. DJP Share this post Link to post Share on other sites
Evolution 34 Posted November 14, 2016 I'm sure you've already checked this out? https://www.chiefarchitect.com/support/article/KB-00673/creating-corner-windows.html or Share this post Link to post Share on other sites
stephenbc 3 Posted January 26, 2018 Picking up on this older thread, I'm trying to place nanawalls on two walls, one of them curved. Using the pass-thru window as the initial work-around to create the opening, it seems to work fine for walls that are orthogonal to each other. But, I'm having difficulty getting the required behaviour for a corner that has one slightly curved wall. That is, I'd like to remove the corner portion of the wall. Any ideas on how to get this to work? An example is attached. Corner windows.plan Share this post Link to post Share on other sites
