payettedesigns Posted November 13, 2016 Share Posted November 13, 2016 I am doing a story and a half addition with a staircase in the rear corner of the addition. Chief balloon frames the walls around the auto generated stairwell. My Exterior walls are 2"x 6" 16" O.C which is more than enough beef to hang the stairs on. I do not want to balloon frame these walls. I tried breaking these walls and doing a frame rebuild to no avail. I want to run plates on top and bottom and rim and band just like the normal floor platform. There is nothing structurally wrong with the way chief generates it but it is a lot stronger to frame it the way I want. Instead of using open below I tried using a poly-line and cutting a hole in the floor platform but that is tedious for sure and almost impossible to get everything to line up. if I spent hours I could re-frame in 3D frame view but that does not even show up when you do a frame section of the wall. Any suggestions anyone.? Link to comment Share on other sites More sharing options...
Chopsaw Posted November 13, 2016 Share Posted November 13, 2016 David, There may be an elegant solution to this but if you must manually re frame, it is much faster to edit the Wall Detail than to edit in 3D. Link to comment Share on other sites More sharing options...
dshall Posted November 13, 2016 Share Posted November 13, 2016 On 11/13/2016 at 5:22 AM, payettedesigns said: ....Any suggestions anyone.? Yes, put in a floor (defined as open to below) where you want the break in the balloon frame wall..... Link to comment Share on other sites More sharing options...
