Floor not showing up in garage?
SingletonRW
Go to solution Solved by dshall,
I was using floor camera, instead of full camera. It don't show up in floor camera.
Okay,  I should of known that....  I never never never use the FLOOR CAMERA,  I never got in the habit of using the FLOOR CAMERA........  why would you ever use the FLOOR CAMERA?  Do you find any advantage of using a FLOOR CAMERA vs a FLOOR OVERVIEW CAMERA?
I think I get the same info from a FLOOR OVERVIEW CAMERA instead of using the FLOOR CAMERA.  I think the main difference is with the FLOOR CAMERA is you do not get upper and lower floors whereas with the FLOOR OVERVIEW CAMERA,  you will always get the floor the view was taken from and any floors below.
I use the hot keys and I never set up a hot key for the FLOOR CAMERA so I never use it.
Thanks for the question,  it got me thinking.
