rlackore Posted November 9, 2016 Share Posted November 9, 2016 Adjust Sunlight>Use Sun Angle has a drop-down box. It is never populated with any choice other than what the current Sun Angle is set to: Am I missing something? Is there a way to designate multiple Sun Angles so I can select which I want for a particular render/raytrace without having to use the Edit option? Link to comment Share on other sites More sharing options...
Solution dshall Posted November 9, 2016 Solution Share Posted November 9, 2016 Adjust Sunlight>Use Sun Angle has a drop-down box. It is never populated with any choice other than what the current Sun Angle is set to: adjustdbx.PNG Am I missing something? Is there a way to designate multiple Sun Angles so I can select which I want for a particular render/raytrace without having to use the Edit option? Yes, you are missing something. Put in a sun angle in and then you will have an option. Put in multiple sun angles and you will have multiple options. Note that in may plan I 6 sun angles. 1 Link to comment Share on other sites More sharing options...
rlackore Posted November 9, 2016 Author Share Posted November 9, 2016 I should have tried inserting more than one Sun Angle. Thank you for the solution. Link to comment Share on other sites More sharing options...
dshall Posted November 9, 2016 Share Posted November 9, 2016 You know, I would of thought my buddy Racklamore would of given me a point....... but nooooooo!...... that's okay, I still think he is a good guy. Link to comment Share on other sites More sharing options...
rlackore Posted November 9, 2016 Author Share Posted November 9, 2016 Teach me how to give points and I'll give you two - one for solving this thread, and one for showing me how to give points. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 9, 2016 Share Posted November 9, 2016 Press the green arrow on his post. 1 Link to comment Share on other sites More sharing options...
rlackore Posted November 9, 2016 Author Share Posted November 9, 2016 Thanks Joe; but Scott may have an issue with you taking his point for teaching me how. Link to comment Share on other sites More sharing options...
