Adjust Sunlight DBX
rlackore
Go to solution Solved by dshall,
Adjust Sunlight>Use Sun Angle has a drop-down box. It is never populated with any choice other than what the current Sun Angle is set to:
Am I missing something? Is there a way to designate multiple Sun Angles so I can select which I want for a particular render/raytrace without having to use the Edit option?
  • Solution
Yes,  you are missing something.  Put in a sun angle in and then you will have an option.  Put in multiple sun angles and you will have multiple options.  Note that in may plan I 6 sun angles.
